  2. Functional Verification
  3. UniPro eVC integration
  • Subscribers 66
  • Views 13279
PeterSVerif
PeterSVerif over 12 years ago
I'd like to integrate the CDN UniPro eVC to a verification component, that will be reused multiple times. I noticed that each layer in the UniPro stack communicates upwards and downward via method ports. My idea is to reuse the upward method-ports of the transaction layer to communicate with the UniPro eVC (drive, monitor the UniPro operation from a higher layer). To do so , I need to know the definition of the method-type of each port, but I could not find it in the documetation of the eVC.
Is there a way to get information about those method ports?
Can you suggest better way to integrate the UniPro eVC?
Best Regards,
Peter
