  2. Functional Verification
  3. convert string to list of bit
  • Subscribers 66
  • Views 14620
mmbr
mmbr over 12 years ago
I'm looking for a way to read a file containing (HEX) numbers.
For each file I read, the width of the data is different (can be more than 32/64/128 bits).
So I'm looking for a way to convert the string I read from the file to a list of bit variable.
In order to make it easy, let say I know the size of the bits list (the data width) in advance.
Any ideas?
  • muffi
    muffi over 12 years ago
    extend sys{
      run() is also{
        var m_file: file;
        var list1: list of uint;
        if files.file_is_readable("text.txt"){
          m_file = files.open("text.txt", "r", "Text File");
          var m_string: string;
          while files.read(m_file, m_string) {
            list1.add(append("0x", m_string).as_a(int));
          print list1 using hex;
          files.close(m_file);
    text.txt
    234d
    134d
    254d
    034d
    234a
    294b
    844a
    234d
  • mmbr
    muffi Hi,
    In your example list1 is a list of uint.
    I'm looking for a solution where list1 is a list of bit.
    Lets take for example a file containg a line with the number f3.
    var lob : list of bit;
    var lob_size : uint = 5;
    After the convertion function I would like to get lob with this list:
    Specman> p lob using dec
      lob =  (5 items, dec):
                                                    1  0 0 1 1      .0
    Specman> p lob using hex
      lob =  (5 items, hex):
                                                    1  0 0 1 1      .0
