  2. Functional Verification
  3. clocking...endclocking block question in the ifv
  • Subscribers 66
  • Views 14316
DouglasYaya
DouglasYaya over 12 years ago
Hi, All
I am a new beginner in the IFV, now I have a question of  how to implement the clocking...endclocking in IFV.
For the following code, I am intened to see the "din" in the waveform has a delay of 3ns to the "clk", I have never successed, could you tell me wheter the code has some issue(e.g., missed ports declaration) or list several key TCL commands for it?
I really appreciate you help!
Douglas
`timescale 1ns/1ps
module  reg_s
        clk,
        rst,
        din,
        dout
    input                       rst;
    input                       clk;
    input                       din;
    output                      dout;
    reg                         dout;
    always @(posedge rst or posedge clk)
    begin
        if(rst == 1'b1)
        begin
            dout    <= 1'b0;
        end
        else
        begin
            dout    <= din;
        end
    end
endmodule
interface   reg_s_if(input clk);
    logic                       rst;
    logic                       din;
    logic                       dout;
    clocking cb @(posedge clk);
        default input #2ns output #3ns;
        input                 dout;
        output din;
proterty  p_dout;
endproperty
    endclocking
    ap_dout :assert  property(p_dout);
    modport drv_mp(clocking cb, output rst);
    modport dut_mp(input din, rst, output dout);
endinterface
module  tb;
    logic                       clk;
    initial
    begin
        clk     = 1'b0;
        forever
        begin
            #5ns;
            clk = ~clk;
        end
    end
    reg_s_if        u_reg_s_if(clk);
    reg_s           u_reg_s
                    .rst    (   u_reg_s_if.rst  ),
                    .clk    (   u_reg_s_if.clk  ),
                    .din    (   u_reg_s_if.din  ),
                    .dout   (   u_reg_s_if.dout )
endmodule
  • TAM1
    TAM1 over 12 years ago
     IFV is doing a formal proof and to do so it reduces the circuit description to a cycle-based model. As a cycle-based model, all of the timing information is ignored. The circuit will only change state on the edges of the clocks that you've defined. The effects of a clocking block will only be visible during a simulation run.
  • DouglasYaya
    Thank you, TAM1, you've corrected my understanding!
    Yes, exactly, I can see the timing effect during the simulation run(In QestaSim) but not the IFV.
    BTW, I want to confirm again, you mean the "only simulation run", is that something like such one? Since I successed the timing effect in this pattern.
     program automatic test(...) ;
    logic ...;
    logic ...;
      dut u_dut(...);
    intial
    begin
    end
    endporgram
