  2. Functional Verification
  3. Op-amp which can work at 100 kHz in PSpice
  • Subscribers 66
  • Views 14031
Shalinii
Shalinii over 12 years ago
I am looking for an op-amp which can be used as a comparator at 100 kHz frequency. I am using uA741 and it works fine upto 10 kHz frequency but not beyond that. Could anyone please suggest an opamp that works at 100 kHz in PSpice? Thanks!
  • oldmouldy
    oldmouldy over 12 years ago
    An LM311 Comparator will probably fit your needs, if not search for a more appropriate spec device and get a SPICE model for it. If you are running in Lite, unlicensed, mode only the parts in the configured Eval Library are supported.
