  2. Functional Verification
  3. SystemC ncelab error
  • Subscribers 66
  • Views 16903
MJT45
MJT45 over 11 years ago
I'm trying to get a SystemC / Verilog simulation to run and am getting the following error messages:
There is no information on any of the warning or error codes in Cadence help or on this site. Has anyone got more information in these or suggestions on how to resolve them?
ncelab: *W,CUSRCH: Resolved design unit 'BLAH' at 'U_BLAH' to 'work.BLAH:v' through a global search of all libraries.
ncelab: *E,SCK109: complete binding failed: port is not bound to any interface: port 'tb.dut.signal_in' (sc_in)
In file: sc_port.cpp:247
In phase: end_of_elaboration.
ncelab: *E,SCK940: Error in SystemC elaboration
In file: sc_cosim.cpp:1249
ncelab: Memory Usage - 31.4M program + 72.5M data = 103.9M total (Peak 104.6M)
ncelab: CPU Usage - 0.1s system + 1.6s user = 1.6s total (2.2s, 74.7% cpu)
ncsc_run: *E,TBELABF: ncelab returned non-zero exit status
make: *** [comp_sc] Error 1
  • muffi
    muffi over 11 years ago
     > nchelp ncelab sck109
    nchelp: 12.20-s028: (c) Copyright 1995-2014 Cadence Design Systems, Inc.
    ncelab/sck109 =
            Port binding resolution done at end of elaboration has failed.
            This can happen if:
            1) A port is unbound.
            2) A port is bound to more interfaces than the maximum specified.
            3) A port declared with the SC_ALL_BOUND policy has less interfaces
               bound to it than the maximum specified.
            4) A port is bound more than once to the same interface.
    Ports in SystemC must be bound to at least 1 channel.
  • MJT45
     Thanks. I've fixed the error which was causing the port binding problem but now get the following error:
     ncsim: sc_cor_qt.cpp:161: virtual void sc_core::sc_cor_qt::stack_protect(bool): Assertion `ret == 0' failed.
    The same code simulated in Modelsim doesn't give this error.
  • muffi
    Please check your code to see if an sc_module is being instantiated as a global variable before sc_main
    We may require more information to debug this. For that, can you send in a mail to support@cadence.com?
