  2. Functional Verification
  3. Poor generation distribution results using count() method...
  • Subscribers 66
  • Views 13936
myonlyscreen
myonlyscreen over 11 years ago
Hi
I am facing some  problem using the count() method in list generation.
I have summarized it to the test case shown in the next code:
struct tc_s {
    active  : bool;
    keep soft not active;
extend sys {
    l : list of  tc_s;
    keep l.size() == 10;
    keep for each in l {
        it.name == index.to_string();
    keep l.count(it.active == TRUE) == 2;
    run() is also {
        for i from 0 to 20 {
            gen l;
            print l;
When examining  the  generation results, I got all the items in the list to look like this:
item   type        name        active
0.     tc_s        "0"         FALSE
1.     tc_s        "1"         FALSE
2.     tc_s        "2"         FALSE
3.     tc_s        "3"         FALSE
4.     tc_s        "4"         FALSE
5.     tc_s        "5"         FALSE
6.     tc_s        "6"         FALSE
7.     tc_s        "7"         FALSE
8.     tc_s        "8"         TRUE
9.     tc_s        "9"         TRUE
The 2 last items always got the TRUE'active and the others not, why isn't it distributed over all the list items ?
Regards.
E.M.
  • hannes
    hannes over 11 years ago
    This has to do with the soft constraint on active. The solver is trying to enforce the soft as much as possible, and only when it gets to the end of the list it MUST violate it, to enforce the count. The distribution would look better without the soft constraint.
    -hannes
  • myonlyscreen
     Thanks a lot !
