  2. Functional Verification
  3. ADE L Outputs Window does not work
  • Subscribers 66
  • Views 14573
hoorayitsjohn
hoorayitsjohn over 11 years ago
The way I have always probed currents/voltages in ADE was to go to "Outputs>to be plotted>select on schematic" and click every node/pin I need.  Now that I've moved to a new system this function does not work.  The nodes show up in the outputs window, but when I run a simple single point dc analysis they do not appear.
 details:
- I can annotate the node voltages and device operating points on the schematic with no problems
- If I use the calculator to form an equation (i.e. 'VDC("/OUTPUT")', and copy paste it in a row in the output window it will show up as expected, but it takes forever to do this for several nodes/currents.
- This is while using spectre
 There seems to be some disconnect between the saved data and the display on the ouputs window.  Anyone have a clue?
 Thanks.
  • StephenH
    StephenH over 11 years ago
    Try asking on the Custom IC forum: http://www.cadence.com/community/forums/38.aspx, this section is mainly populated by digital folks :)
