  2. Functional Verification
  3. increase virtual memory to sn_compile.sh
  • Replies 7
  • Subscribers 67
  • Views 16907
amirb
amirb over 11 years ago
How do I increase the virtual memory allocated to sn_compile.sh? We have an environment compilation crashing because of an “out of virtual memory” error.
  • hannes
    hannes over 11 years ago
    I believe virtual memory is related to the OS, so this can not really be controlled by chaning some sn_compile or Specman flag.
    Please can you be a bit more specific, and share the error message and sn_compile parameters.
    Another option would be to optimize the compilation by using the -parallel option. This should reduce the size of the generated C code,  improve compilation performance and reduce the amount of virtual memory required.
    -hannes
  • amirb
    My command is:
    sn_compile.sh -shlib /vobs/cc33xx/modules/wsoc_wmac/SPECMAN/E_USR/pmac_top.e -enable_DAC -e /sim/cc33xx/wsoc_wmac/cc33xx_amirb_int2/SNAPSHOTS/wsoc_wmac_tb/wsoc_wmac_tb.lnx8664.13.20.nc/specman.13.20.002-p/scratch -t /sim/cc33xx/wsoc_wmac/cc33xx_amirb_int2/SNAPSHOTS/wsoc_wmac_tb/wsoc_wmac_tb.lnx8664.13.20.nc/specman.13.20.002-p/scratch/precomp_tmp -o libsn_precomp.so
    And my error  message is:
    # Compiling C modules using /apps/cds/incisiv/13.20.002/tools.lnx86/cdsgcc/gcc/bin/64bit/gcc
    [3]    Done                          bsub -q gui -Is specview
    cc1: out of memory allocating 4064 bytes after a total of 175792128 bytes
    # sn_compile.sh: error during compilation, exiting
    Amir
  • Tudor Timi
    Tudor Timi over 11 years ago
    Hi Amir,
    The "[3] Done..." message suggests you might be using LSF to submit your compile command to a different machine. While I can't know your exact setup, make sure that the queue you are submitting to doesn't have any memory usage restrictions. Also, you can tweak bsubs to request more memories by using the -R (requirements) command line argument. In our compute environment for example we would do something like '     bsub -R "mem > 512" <compile command>     ' to request at least 512 MB of memory for the command.
    Cheers,
    Tudor
  • hannes
    I still would recommend to use sn_compile.sh -parallel, just to reduce the size of the C file.
    In addition, you can try to find out what the limits are on the machine where you compile and maybe increase them
    (ulimit -a and ulimit -v unlimited).
    -hannes
  • amirb
    Thanks, the -parallel did the trick!
    PS: I would like to cc you on my mail with Cadence Israel, can you send me your mail address.
  • amirb
    By the way, does using the -parallel option hurt the performance of the executable created by the sn_compile.sh script?
    thanks,
    Amir
  • hannes
    No, it doesn't.
    -parallel: instead of creating on big C file and compiling that, sn_compile.sh creates several (depending on the options) and compiles each in a separate call/process. The result is the same.
