  2. Functional Verification
  3. query on scope of events in e language
  • Subscribers 65
  • Views 14182
jaichandra
jaichandra over 11 years ago
Hi
   My verification environment is in e language completely.  I want to access the events of an unit from top level sequences i build. earlier i used to accesses the events anywhere in the seqeunces using the code shown below.
wait @get_enclosing_unit(top_unit).unit1.unit2.unit3.target_unit.event_name;
Now the same code i am not able to see the events. The sequence keep waiting for the event. But the event is already generated in the target_unit.
I am confused why it is not working now.  Any help is greatly appreciated.
- regards
  • StephenH
    StephenH over 11 years ago
    Are you sure that the wait statement was executed before the target unit emitted the event? If you use the command "trace event target_unit.event_name" you'll see in the log every time the event is emitted. You could also put a message print-out right before your wait statement.
    If they're happening in the same time step you might consider using the "sync" statement instead of "wait", because sync can complete in the same time slot if the event was already emitted in that time slot, whereas wait needs to have been executed before the event is emitted.
    From the documentation: "The sync action is similar to the wait action, except that a wait action always requires at least one cycle of the TCM's sampling event before execution can continue. With a sync action, execution can continue in the same Specman tick."
  • jaichandra
    Hi stephen,
                     Thanks for your reply. My issue is resolved. There was no problem with the code. But the issue was with the clock. The sequence driver clock was getting gated in between becasue of which the driver was not able to see the events. I changed the clock source after which the code worked fine. Thanks for you reply.
