  2. Functional Verification
  3. INCISIV132/122 does not support some systemverilog 2012...
  • Subscribers 66
  • Views 1062
INCISIV132/122 does not support some systemverilog 2012 coverage coding
JennyYang
JennyYang over 11 years ago
INCISIV132/122 does not support following coverage code with error report:
 "ncvlog: *E, ECBECL… Range specification for a bin must start with (‘{’)"
/// ------------- coding start -----------------
bit [6:0] sbyte;
covergroup cg;
  coverpoint sbyte {
    bins mod3 [  ] = sbyte with {item % 3 == 0};
endgroup
/// ------------- coding end   -----------------
Can anyone give me feedback ?
  • Shalom B
    Shalom B over 11 years ago
    'mod3[' should be 'mod3[', and 'with' should be followed by parentheses, not curly brackets.
  • StephenH
    StephenH over 11 years ago
    As Shalom pointed out, you need parenthese not curly brackets around the with expression. I think the forum software corrupted your text and I assume you did actually have a closing square bracket after the mod3.
    As far as I can see this isn't supported yet, so it would be great if you could file a support case at http://support.cadence.com/ indicating the severity of the problem. This helps our R&D team  to prioritise the implementation of the new features, which we can't do from a public forum.
