  2. Functional Verification
  3. Currently type parameter override is not supported for this...
  • Subscribers 67
  • Views 16588
Currently type parameter override is not supported for this datatype.
Chandra Singh
Chandra Singh over 11 years ago
Hello all,
I am getting following error  "Currently type parameter override is not supported for this datatype."   for the  code given below
In the tb_top.sv we are setting this mailbox
uvm_config_db#(usbpd_prot_pkt_mailbox_t) :: set(null, "*","dut_prot2pe_mbx_0" , dut_prot2pe_mbx[0]);
In lower layer component
if(!uvm_config_db #(usbpd_prot_pkt_mailbox_t) :: get(this, "", "dut_prot2pe_mbx_0", this.prot2pe_mbx))
            `uvm_error("USB_PD", $psprintf("TB_DRIVER :GET_CONFIG_FAILED STATUS:dut_prot2pe_mbx"))
During compilation this error is comming.
ncvlog: *E,SVTPCO (../../uvm_tb/driver/usb_pd_prot_driver.sv,52|52): Currently type parameter override is not supported for this datatype.
  • seabeam
    seabeam over 11 years ago
    It seemed that cadence's tool do not support transfer type:mailbox, array, queue through config_db(unfortunately tlm port, export, ap, is based on mailbox, which cannot be pass). But mentor's tool can work properly.
    In IEEE std. 1800-2009, this situation is not mentioned.
  • StephenH
    StephenH over 11 years ago
    If you want support for tool problems, please use the correct procedure at our support site  as we cannot do much in a public forum to analyse your problems.
    Luckily for you the solution to your issue is quite easy: create a wrapper class around the mailbox, since you can use classes with the config DB.
  • Tudor Timi
    Tudor Timi over 11 years ago
    Try to wrap your mailbox in a class and pass that. This might work. Here's some code (not tested):
    class mailbox_wrapper;
      usbpd_prot_pkt_mailbox_t mbox;
    endclass
    mbox_wrapper wrapper = new();
    wrapper.mbox = dut_prot2pe_mbx[0];
    uvm_config_db #(mailbox_wrapper) :: set(null, "*","dut_prot2pe_mbx_0" , wrapper);
    You'll also have to update your get to handle the wrapper class instead of a native mailbox.
  • StephenH
    Here's an example. This hasn't been tested but should be complete.
    package mbox_pkg;
    import uvm_pkg::*;
    class mbox_wrap #(type T=uvm_object);
      mailbox #(T) mbox;
      function new (int bound=0);
        mbox=new(bound);
      endfunction
      function int num();
        return mbox.num();
      endfunction
      task put (input T message);
        mbox.put(message);
      endtask
      function int try_put (input T message);
        return mbox.try_put(message);
      endfunction
      task get (ref T message);
        mbox.get(message);
      endtask
      function int try_get (ref T message);
        return mbox.try_get(message);
      endfunction
      task peek (ref T message);
        mbox.peek(message);
      endtask
      function int try_peek (ref T message);
        return mbox.try_peek(message);
      endfunction
    endclass
    endpackage
