  2. Functional Verification
  3. NCVHDL simulation error
  • Subscribers 66
  • Views 14256
Jinesh K B
Jinesh K B over 11 years ago
Sir, am getting this error when trying to elaborate the design
[root@localhost simulation]# ncelab WORK.trial:trial_rtl
ncelab: 10.20-p008: (c) Copyright 1995-2010 Cadence Design Systems, Inc.
ncelab: *W,DLMLUP: Unable to access modified marker for library 'std'.
        file: /cad/INCISIV102_lnx86/tools/inca/files/STD/.cdsvmod (Permission denied).
ncelab: *W,DLMLUP: Unable to access modified marker for library 'synopsys'.
        file: /cad/INCISIV102_lnx86/tools/inca/files/SYNOPSYS/.cdsvmod (Permission denied).
ncelab: *W,DLMLUP: Unable to access modified marker for library 'ieee'.
        file: /cad/INCISIV102_lnx86/tools/inca/files/IEEE/.cdsvmod (Permission denied).
ncvhdl_cg: *W,DLMLUP: Unable to access modified marker for library 'ieee'.
ncvhdl_cg: *W,DLMLUP: Unable to access modified marker for library 'std'.
ncvhdl_cg: *W,DLMLUP: Unable to access modified marker for library 'synopsys'.
  • StephenH
    StephenH over 11 years ago
    These are not errors, they are warnings; the *W indicates the severity and will be one of I (Information), W (Warning), E (Error, can continue) or F (Fatal, must exit immediately). I suspect you're seeing these because you're running as the same user ID as the tool was installed as. In fact it looks like you're running as root, which would be a very risky thing to do, it's always best to use a regular user-level account for everything in Linux. You are also running an extremely old Incisive version, Cadence stopped supporting 10.20 years ago :) I strongly recommend that you install a newer and supported version like 14.10.
  • Jinesh K B
    Thanks for your reply sir. I want to use memory modules in my project (to store intermediate image datas),is there inbuilt memory IP cores available for users, how to use them. I searched but didn't get any idea about this.
