  2. Functional Verification
  3. How to correctly run specman with ncsim ?
  • Subscribers 66
  • Views 14742
VaclavPeroutka
VaclavPeroutka over 10 years ago
I started to experiment with VHDL+Specman. I wrote some code and now I want to simulate VHDL and E together. I use following command to run the simulation:
specview ncsim -gui -cdslib /proj/specman_first_xortest/cds.lib -logfile ncsim.log -errormax 15 -status worklib.tb_xortest:tb
But I am getting following messages:
*Novas* Loading libsscore_ius121.so
*Novas* libsscore_ius121.so: cannot open shared object file: No such file or directory
*Novas* Cannot load libsscore_ius121.so from following LD_LIBRARY_PATH
/cad/cds/incisiv/incisiv12.20.011/tools/lib/64bit:/cad/cds/incisiv/incisiv12.20.011/tools/lib:/cad/cliosoft/sos/sos_6.31.p2/
lib:/cad/cliosoft/sos/sos_6.31.p2/lib/64bit:/custom/tools/apps/release5/ONpli/64bit:/custom/tools/apps/release5/ONpli/32bit:
/site/custom/tools/apps/gtkextra/lib:/custom/tools/it/rtda/2013.09/linux64/lib:/cad/cds/incisiv/incisiv12.20.011/specman/lin
ux64
*Novas* Failed to load FSDB dumper.
Relinquished control to SimVision...
Failed to register epi test phase change update callback.
Failed to register epi unit tree update callback.
ncsim>
ncsim> source /cad/cds/incisiv/incisiv12.20.011/tools/inca/files/ncsimrc
What is going wrong and what can I do to correctly run the simulation ?
  • hannes
    hannes over 10 years ago
    It looks like you have some trouble with your integration of Novas. Make sure that the mentioned .so file is available, and also on the LD_LIBRARY_PATH. You can also have a look in the IES installation under <IES-install>/specman/examples/Waveform/Verdi. There is a demo on how to run IES+SN+Verdi. If you still can't progress, please file a support ticket via support.cadence.com
    -hannes
