  2. Functional Verification
  3. re: new version 14.10-s012 with assertions
  • Subscribers 66
  • Views 15094
Srikanth Madam
Srikanth Madam over 10 years ago
i have written a simple assertion to check for 2 pulse as
property(p1);
     @(posedge clk)
      ($rose(in1) ##1 $fell(in1)) |-> ##[1:$] ($rose(out1) ##1 $fell(out1));
endproperty
Assuming at out1 is remains as 0(zero) through out the simulation. I should get assertion failure at the end of the simulation, but instead it is not giving messages (like vacuous success). But with the older version i am getting failure message. So help me out here.
Srikanth M.
  • muffi
    muffi over 10 years ago
    Can you add the "–abvevalnochange" switch and see if it makes a difference?
    This is a compile time option that enables assertion evaluation even if the assertion input variables/expressions are not changing. By default such assertion evaluations are optimized out.
  • Srikanth Madam
    Still no change
  • TAM1
    TAM1 over 10 years ago
    In the original SVA spec, all assertions were "strong" and had to complete before the end of a simulation. But in the latest version, a new "strong" keyword was added and all assertions became "weak" by default. This was preferred so people didn't get a lot of spurious errors when they terminated their simulations. You surround the terminating sequence with "strong ( ##[1:$] $rose(out1) ##1 $fell(out1) )".
