  2. Functional Verification
  3. using sys.realtime
  • Subscribers 66
  • Views 13807
using sys.realtime
Yael K
Yael K over 10 years ago
 Can you please explain the influence of the `timescale and precision on sys.time and sys.realtime.
 In specman e language reference it says that:
* "A field of type real named sys.realtime, which can hold a more precise simulator time than sys.time."
* "The precision of the timescale scales the precision of sys.realtime."
For example, I'm using 1ns/10ps but when I try to print sys.time and sys.realtime the same value is printed.
my code does the following:
event xx is fall ('hdl_path')@sim;
on xx {
  print sys.time;
  print sys.realtime;
 In addition using delay() with t : real where t = 1.5 doesn't work.
 So can you please clarify the difference between the two and how to use them correctly?
 Thanks!
 Yael
