  2. Functional Verification
  3. DMS UVC Components
  • Subscribers 66
  • Views 15042
DMS UVC Components
andersonsv
andersonsv over 10 years ago
Good Morning.
I would like to check who I can talk about the DMS UVC Components used for Mixed-Signal Verification.
There are some Mixed-signal RAKs, examples inside the Cadence’s Verification Kit and Technical Papers about mixed-signal verification from Cadence, and they all make reference to DMS UVC Mixed-signal Verification Components. However, there isn’t proper documentation and when I checked the files, they were created around 2010 and looked like were still in development with some hard-coded options/interfaces.
My questions are:
How I can get the most updated version and its documentation?
Who could give us some support about that Verification Component?
 Thank you in advance.
 Best regards.
  • StephenH
    StephenH over 10 years ago
    Hello Anderson.
    It sounds like you found an old copy of the kits; the latest is on the Cadence support system here:
    These should be more up to date. If those aren't matching your needs, it's best to either ping your Cadence sales account manager or file a support request at and you'll be connected to the right person.
  • andersonsv
    Hello, Stephen.
    I already have the most updated RAKs.
    There isn't an RAK for Mixed-Signal Verification using the DMS UVCs.
    The files that I'm referring to are inside the Incisive's Verification Kit that come with it.
    The name of the lab is "Incisive Verification Kits with Methodology Digital Mixed Signal Simulation Workshop".
    Regards.
    Anderson
