  2. Functional Verification
  3. Error of undeclared identifier while calling c-function...
  • Subscribers 66
  • Views 15290
Error of undeclared identifier while calling c-function in VHDL with ncsim
jayvyas13
jayvyas13 over 10 years ago
I am getting error of undeclared identifier while calling c-function in VHDL with ncsim.
I am trying to call C-functions existing in a .so filed - c_api.so inside a VHDL file, something like:
begin
    wait for 1 ns;
    if ( RESETEN = '1') then
       c_matrix_multi( size, cofficient_m1, cofficient_m2, cofficient_reduced);
    end if;
    wait;
end process initial;
But i am getting following error of c-function name "c_matrix_multi" not declared.
ncvhdl_p: *E,IDENTU (.../compute_cofficient.vhd,107|46): identifier (c_matrix_multi) is not declared [10.3].
Plz, provide a sample code of c-function being used inside VHDL using three steps (compile, elab and run).
  • StephenH
    StephenH over 10 years ago
    There is no way to call foreign language functions directly from VHDL, the simulator assumes all references are native to VHDL unless you explicitly declare them to be "foreign", i.e. in another language domain. For SystemVerilog it's really easy using the DPI, but for VHDL things are slightly more complex. You will need to study the Foreign Model Import library (FMI) documentation to understand how to declare your C code within the VHDL so that you can make the calls the way you want. There is a worked example in the simulator installation directory: `ncroot`/inca/examples/cif/import_function/, and you can get eh right part of the docs by running the Linux command "cdnshelp -search 'Foreign Model Integration' ".
