  2. Functional Verification
  3. IRUN command to change the Assertion severity level
  • Subscribers 66
  • Views 20266
mahee424
mahee424 over 9 years ago
   I'm new to assertions and i've written the following property in my interface.
  property p1;
    @(posedge clk) (data == 2'h2) ##[1:6]  (data1 == 2'h2);
 endproperty
always@(posedge clk) assert property (p1);
When i run; the simulation is suddenly stops after the first assertion failure. I want to change the severity of assertion from ERROR to warning.
Please help in this regard?
REGARDS,
MAHEE
  • StephenH
    StephenH over 9 years ago
    Simply add the following after the assert (right before the semi-colon).
    $warning("your message here")
  • mahee424
    Hi, Even after making $warning message the simulation is stops when the assertion fails. This is observed when i run in GUI mode.
  • tpylant
    tpylant over 9 years ago
    Try using the TCL command:
    set assert_stop_level never
    TIm
  • mahee424
    Hi tpylant,
          Can we have irun switch instead TCL to change the severity of assertion or to continue simulation even found assertion failure?
    regards,
    mahee
  • StephenH
    irun -input '@set assert_stop_level never'
