  2. Functional Verification
  3. How to run a regression for multiple testcases with only...
  • Subscribers 67
  • Views 18179
How to run a regression for multiple testcases with only a single compile using NCsim?
ReubenMijares
ReubenMijares over 9 years ago
I would like to do a regression and it requires multiple testcases.
I did this by writing a Bash script which loops until all the testcases are simulated.
However, this loop will repeatedly compile. Is there a way to do only a single compile and then run multiple testcases without recompiling?
Thanks.
Reuben
  • StephenH
    StephenH over 9 years ago
    Hi Reuben.
    Once you have compiled the first time (before entering the loop in your script), a "simulation snapshot" is written into INCA_libs.
    For subsequent runs this snapshot should be automatically reused if you don't change the file list or any irun options that would trigger a recompile (for example changing a -define option). However you can explicitly ask irun to use the previously elaborated simulation snapshot, by passing the -R option to irun. You would normally do this instead of passing any source file names, but if you do pass source files to irun -R, it'll ignore the files and issue a warning.
    So your simple regression flow would look like:
    irun -elaborate *.sv -uvm
    for testname in $(cat testlist); do
    irun -R +UVM_TESTNAME=$testname
    done
  • ReubenMijares
    Thanks! It's working! =)
  • cmarqu
    cmarqu over 9 years ago
    Hi Reuben,
    instead of using (and probably continually extending and improving) your bash script, you may want to take a look at VUnit (http://vunit.github.io/) for running your regressions. There is an "incisive" branch on GitHub that supports irun. If you have any feedback, please use one of the ways provided on the VUnit website.
