  2. Functional Verification
  3. NCSIM selective compile
  • Subscribers 66
  • Views 15652
SimhanAnalog
SimhanAnalog over 9 years ago
        I have a question regarding ncsim digital simulation. Hope this is the right place to post.
I have a huge design that takes a long time to compile and elaborate before starting the sim. For every sim I only modify one file(top level systemverilog testbench). But I need to compile and elaborate all the files to generate the snapshot and then run simulation. It takes about 10 mins for this process. Since I am only modifying one file is there a way to selectively compile and elaborate only that file in order to save time. Some kind of incremental build. I am aware of the -R option in irun, but it does not incorporate the changes that I made to the one file in question.
Another related question:    There is a possibility that other design files might have also changed over time. But is there a way to make sure that the incremental compile and elaborate happens only to the one file in question while discarding the changes(if any) made to other files.
  • StephenH
    StephenH over 9 years ago
    This sounds like an ideal application for multi-snapshot incremental elaboration.
    Have a look at the rapid adoption kit here: http://support.cadence.com/wps/mypoc/cos?urile=deeplinkmin:DocumentViewer;src=wp;q=ProductInformation/Functional_Verification/Incisive_RAKs/Incisive_RAK.htm
    in particular: UVM Multi-Snapshot Incremental Elaboration(MSIE)
    and Incremental Elaboration
  • SimhanAnalog
    Thanks for the reply. I will have a look.
