  2. Functional Verification
  3. Iterator Index Query is having a compile error
  • Subscribers 66
  • Views 14185
ReubenMijares
ReubenMijares over 9 years ago
I'm having a compile error when using the iterator index query of the array methods.
The compile error says, "Hierarchical name component lookup failed". It points to index.
The code is below,
Is this not working for Incisive?
Reuben
  • muffi
    muffi over 9 years ago
    Array iterator method 'index' is not supported yet. The workaround is to write a for-loop as shown below.
    module foo;
    int arr[];
    int qi[$];
    initial begin
      arr = {3, 2, 1};
      //qi = arr.find with (item == item.index);
      for(int i = 0; i<arr.size; i++)
      begin
        if (arr[i] == i) qi = {qi,i};
      end
    end
    endmodule
    20447878 (COS) Workaround for querying an array's iterator index through item.index
  • ReubenMijares
    I see. Thanks for the info.
