  2. Functional Verification
  3. Adding -xprop option causes license issue
  • Subscribers 66
  • Views 3970
ReubenMijares
ReubenMijares over 9 years ago
When I add the -xprop option, a license issue suddenly appears. It says unable to checkout license.
But when I remove this, I'm able to run simulation. Is there an issue with it or am I doing it incorrectly.
The command I used is below:
irun \
-clean \
-xprop F \
-input dump.tcl \
-access rwc \
try_init.sv
Kindly check what is wrong with this.
Thank you.
Reuben
  • ReubenMijares
    Are there any updates on this? I can't run x propagation. When I add that option, it says unable to checkout license (flag -2). I can run simulation if -xprop is omitted.
    Is there something wrong with how I do it?
    Thanks.
    Reuben
  • ReubenMijares
    Okay, I saw in cdnshelp that using xprop requires a special license called Incisive Advanced Option license. How can I enable this? Or, how can I check if this is available?
