  2. Functional Verification
  3. ISSUE: Merging coverage databases for more than 100 tes...
  • Subscribers 66
  • Views 15840
ISSUE: Merging coverage databases for more than 100 testcases
mahee424
mahee424 over 9 years ago
      I've about 400 test cases to merge all the individual coverage data bases to one output file with use of IMC. I'm using below IMC version;
IMC(64): 14.10-s011: (c) Copyright 1995-2014 Cadence Design Systems Inc.
I've found the following error during merging process in BATCH MODE;
mydir> imc -batch
imc>merge mipi_base_test*/scope/mipi_base_test -out final -metrics all -initial_model union_all -message 1
imc>merge: too many arguments
imc>merge: usage: merge [-AeEpqxX3] [-L lab [-L lab [-L lab]]] file1 file2 file3
imc>merge aborted
even i tried giving all the individual test names but still giving the above error.
Can any one suggest me to merge all the 400 test cases?(for my case).
regards,
mahee
  • StephenH
    StephenH over 9 years ago
    The number of tests is not your problem, I can do the same command here and it works.
    % imc -batch
    Starting batch mode
    imc> merge mipi_base_test*/scope/mipi_base_test -out final -metrics all -initial_model union_all -message 1
    *I,MERGL1: Merging IUS Coverage ...
    *I,MERGL1: Preparing target model ...
    *I,MERGL1: Doing model union ...
    *I,MERGL2: With primary run (mipi_base_test_01/scope/mipi_base_test): mipi_base_test_01/scope/icc_27f588a9_00000000.ucm
    *I,MERGL1: Target model generated successfully.
    *I,MERGL1: Projecting IUS ucd data into the target model ...
    *I,MERGL2: mipi_base_test_01/scope/mipi_base_test:
    *I,MERGL3: Merging instance tree tb to tb:
    *I,MERGL3: Data is projected in to the target model.
    *I,MERGL2: mipi_base_test_02/scope/mipi_base_test:
    *I,MERGL2: mipi_base_test_03/scope/mipi_base_test:
    *I,MERGL1: Writing output database cov_work/scope/final:
    *I,MERGL2: Model: cov_work/scope/final/icc_27f588a9_00000000.ucm
    *I,MERGL2: Data : cov_work/scope/final/icc_27f588a9_00000000.ucd
    *I,MERGL1: No Specman coverage databases found in the runs.
    Total conflicts during target model creation: 0
    Total items not merged : 0
    imc>
    So, I'm sure the problem is in your environment somehow. If you'd been pasting the command from an email or documentation, try typing it out manually, in case there are some hidden special characters screwing everything up.
    Please note that 14.10.011 is very old, it came out in early 2014, please consider using a newer version; the last 14.10 update was in May 2016, or you could look at using a supported version such as 15.20.
  • mahee424
    Hi Stephen,
    The problem i made was, The merge command which i have given as below;
    imc> merge mipi_base_test*/scope/mipi_base* -out final -metrics all -initial_model union_all -message 1
    After scope * should be avoided to get merging properly.
    Thanks for the support.
    Mahee
