  2. Functional Verification
  3. Getting error while running dpi-c functions with SV cod...
  • Replies 9
  • Subscribers 66
  • Views 22151
Getting error while running dpi-c functions with SV code
chauhan
chauhan over 8 years ago
Hi all,
I am first time using dpi-c functions in my sv code.When I am trying to call dpi-c functions within sv code using irun command(irun -sv test_c.c test.sv).I have tried ncverilog,ncelab,ncsim also but I m getting same like this error,
make: *** [INCA_libs/irun.lnx86.15.10.nc/ncsc_run/ncsc_obj/test_c_0.o] Error 1
In file included from /usr/include/features.h:385,
                 from /usr/include/stdio.h:28,
                 from $TESTDIR/test_c.c:1:
/usr/include/gnu/stubs.h:7:27: error: gnu/stubs-32.h: No such file or directory
ncsc_run: *E,TBBLDF: Failed to generate object ./INCA_libs/irun.lnx86.15.10.nc/ncsc_run/ncsc_obj/test_c_0.o
irun: *E,CCERR: Error during cc compilation (status 1), exiting.
Please can anyone  help me to know why this error is coming and what wrong I m doing. And can anyone tell me what are the commands and step by step process to run this two files.
Below is my C and SV code :
//sv code
1>
module main;
import "DPI-C" function void hello();
initial
begin
print();
end
endmodule
2>
//c code
#include <stdio.h>
void hello() {
printf("hello from c");
thanks,
JAY
  • tpylant
    tpylant over 8 years ago
    The "-sv" argument on the command line tells irun to use the SV compiler for all files, regardless of filename extension. Try running without the "-sv" switch.
    Tim
  • StephenH
    StephenH over 8 years ago
    I'm going to guess that you're not running on a supported OS. You should be using RedHat Enterprise Linux 5 or 6, and have certain RPMs installed including things like glibc-devel. Please confirm what OS you're using...
  • chauhan
    thank u so much for ur reply...I tried without -sv but still I m getting same error..is there any other way(commands) to compile this files?
  • chauhan
    thank for ur reply ...I m using Red Hat Enterprise Linux Server release 6.7.
  • chauhan
    Is it supported or not ?
  • chauhan
    Is it required to include svdpi.h header file in c code ? because when I m including that I m getting below warning..
    ncsc: compiling $TESTDIR/test_c.c
    In file included from $CDSROOT/tools/include/svdpi.h:80,
    from $TESTDIR/test_c.c:2:
    $CDSROOT/tools/include/svdpi_compatibility.h:48:2: warning: #warning "INCISIV is currently compliant with DPI header file svdpi.h as per IEEE 1800-2005. Starting IUS15.20, the default header file will be as per IEEE 1800-2012. DPI applications which need to continue complying with IEEE 1800-2005 will need to compile with the macro DPI_COMPATIBILITY_VERSION_1800v2005 starting in 15.2. The difference in the two header files is in the declaration of the struct t_vpi_vecval."
  • jaichandra
    jaichandra over 8 years ago
    Hi
    I too use DPI to call my C function from SV environment. I use two step for my simulations. I compile, elaborate and generate the snapshot in one step and simulate in the second step. In my compile script i use -c and -sv options and list both SV and C files using -f option. I am using 15.22-s005 version. I belive your issue could be something realted to environment than to the code itself.
  • chauhan
    can u mention that two steps ? I have tried using file list & -f option also..
  • chauhan
    thank u guys for all your help & suggestions ...but now problem is solved ..it is working fine.
