  2. Functional Verification
  3. Why it must have virtual interface initialized for an embedded...
  • Subscribers 65
  • Views 1705
Why it must have virtual interface initialized for an embedded covergroup before connect_phase()?
Jeff000
Jeff000 over 8 years ago
Refer to the code as below, assignment of vif in build_phase() or connet() will result in different behavior. Anyone can explain a bit for this?
Thanks.
class apb_cov extends uvm_component;
virtual apb_master_if vif;
covergroup cg @ (vif.monitor_cb)
option.per_instance = 1;
endgroup // cg
function new(string name="");
super.new();
cg = new();
endfunction // new
function void build_phase(uvm_phase phase);
super.build_phase();
* If assign vif here, it is ok.
* vif = g_if;
endfunction // build_phase
function void connect();
* If assign vif here, it will give runtime error as
* NULL pointer dereference of vif.
* vif = g_if;
endfunction // connect
endclass // apb_cov
  • tpylant
    tpylant over 8 years ago
    I assume it has to do with the covergroup being created in the "new" function. Since the covergroup references vif.monitor_cb, vif needs to exist. If you want it to assign to vif  in the connect_phase, then you'll need to create cg in the connect_phase.
    Tim
  • Jeff000
    In fact the build_phase() is executed after new() as well. That's why I'm confused with the distinction about the assignment of vif in build_phase() and connect_phase().
    Moreover, the embedded covergroup can not be instantiated outside the new(), or it will issue an error.
