  2. Functional Verification
  3. [ncsim: *W,DLWNEW:] How to locate the intermediate file...
  • Subscribers 65
  • Views 3758
[ncsim: *W,DLWNEW:] How to locate the intermediate file?
Jeff000
Jeff000 over 8 years ago
I just ran into the warning as below,
ncsim: *W,DLWNEW:
Intermediate file module ma.ma_rst:module (VST) is newer than
expected by snapshot worklib.top_dut:sv (SSS)
actual: Wed Jul S 15:55:31 2017
expected: Tue May 9 17:24:51 2017.
The message gives some details about the creation date of the intermediate file. But I still couldn't tell which intermediate file referenced by ncsim.
Is there any way to locate the intermediate file that is undergoing?
Thanks.
  • tpylant
    tpylant over 8 years ago
    The first thing to try is to remove the INCA_libs directory or add "-clean" to the irun command.
    If that doesn't resolve the issue, make sure you're not re-compiling the ma_rst code after elaboration. VSTs are created from "irun -compile" or "ncvlog". Those VSTs are then referenced during elaboration from "irun -c/elaborate" or "ncelab".
    Tim
