  2. Functional Verification
  3. How to get the preprocessor output from irun?
  • Replies 7
  • Subscribers 65
  • Views 5999
Jeff000
Jeff000 over 8 years ago
I've tried
irun -svpp
But I was told that is is deprecated in the latest version.
Is there any way to check the preprocessor output in irun?
Thanks.
  • StephenH
    StephenH over 8 years ago
    Hi.
    The irun svpp mode was deprecated several years ago. It was only ever a stop-gap to handle certain SV constructs that the Incisive parser didn't support at the time.
    If you move to Incisive version 15.20, you won't need svpp. Better still, talk to your local Cadence team about upgrading to Xcelium, which replaced Incisive at the start of 2017, it has very good SV support.
  • Jeff000
    Jeff000 over 8 years ago in reply to StephenH
    Thank you! So I guess Xcelium will support preprocessor output, right?
  • StephenH
    StephenH over 8 years ago in reply to Jeff000
    There is no pre-processor now, all the parsing is done natively. Why do you think you need access to a preprocessor? What are you trying to do?
  • Jeff000
    well, sometimes there're macros which are really complicated, so I think a pre-processor could help to debug in such scenario.
  • muffi
    muffi over 8 years ago in reply to Jeff000
    You can use the "-parseinfo macro" option to irun/xrun.
    By default, -parseinfo macro applies globally, affecting all instances in the design. Optionally, you can limit the report by specifying a list of one or more module names.
    The macro argument provides the following information on these macro instances:
    -- The source code where the macro was used.
    -- The macro definition used to expand the macro instance.
    I hope this helps.
    • Vote Up +2 Vote Down
  • Jeff000
    Jeff000 over 8 years ago in reply to muffi
    Great! Thank you!
  • StephenH
    Ah, for macros, try adding "-parseinfo macro" to see all the macros expanded in the log.
