  2. Functional Verification
  3. How do I uncheck "Process statement" from sidebar in Simvision...
  • Subscribers 68
  • Views 2947
How do I uncheck "Process statement" from sidebar in Simvision?
Ncsim User 1
Ncsim User 1 over 7 years ago
Hi Cadence,
I use latest ncsim and run a large design. I use sidebar to quickly select signals and send to waveform.
My VHDL design is so large that there are tens of "unnamed processes" and "process statements" at the same hierarchy as submodules.
Each time starting ncsim I need to go to Sidebar Options and uncheck these two options in order to make "scope" easier to browse.
Are there any ways to make ncsim uncheck these by default? I noticed the setting is not stored in svcf command scripts.
  • Tudor Timi
    Tudor Timi over 7 years ago
    +1 I'd like to know as well.
  • cmarqu42
    cmarqu42 over 7 years ago
    Just recently, I was looking for the same thing:
    # do not show unnamed processes in design browser of waveform window:
    waveform sidebar access designbrowser options scopetree -showunnamedprocesses 0
    cdnshelp says:
    For a complete list of scope tree options and their current values, enter the following command:
  • Ncsim User 1
    Ncsim User 1 over 7 years ago in reply to cmarqu42
    Thank you Colin.
    It works.
  • StephenH
    StephenH over 7 years ago
    In addition to Colin's Tcl-based solution, I'd like to point out an important point about setting preferences in SimVision: if you use the main menu Edit->Preferences, then make changes there. If you use the "OK" button, the changes are saved in the ~/.simvision/settings file and will be used every time you start SimVision. I do see a lot of folks using the cog wheel in the side bar, to open the preferences dialog, this way of doing it does NOT save the changes, so the changes are lost each time you quit SimVision.
    Note also that in the Edit->Preferences dialog, you can search for words, so typing "process" would filter and highlight all the settings associated with processes, to make them easier to find.
