  2. Functional Verification
  3. How to add hook when exit from simulation?
  • Subscribers 65
  • Views 1475
Jeff000
Jeff000 over 7 years ago
Is it possible to add hooks in UVM testbench or tools to dump some variables in ENV when the simulation is terminated by SIGINT like Ctrl-C?
Thanks.
  • StephenH
    StephenH over 7 years ago
    A simple SV "final" block should do it, unless you manage to crash the simulator!
  • Jeff000
    Jeff000 over 7 years ago in reply to StephenH
    I tried to put some handles of object in the 'final' block, but it seems those objects had been recycled till this point and give a 'null' error.
  • StephenH
    StephenH over 7 years ago in reply to Jeff000
    Very likely. Perhaps you could explain what you're trying to accomplish? You asked about env vars, now you've changed to talking about class handles...
