  2. Functional Verification
  3. NCELAB WOUPSR errors
  • Subscribers 66
  • Views 15144
Ian88
Ian88 over 7 years ago
I have a UVM testbench which gives the following errors when I compile:
$cast(arg, tr); // Need run-time casting because at compile time T1 can be scalar.
ncelab: *E,WOUPSR (/vl/edatools/extern/Cadence/INCISIV/15.2/087/tools/methodology/UVM/CDNS-1.1d/sv/src/tlm1/uvm_tlm_ifs.svh,229|12): A reference to an entire unpacked struct/union is not permitted in this context [SystemVerilog].
However, the code it points to is in the UVM base class library that comes with the installation. Clearly the problem is not with the uvm base class library, but the code in my testbench that calls the function.
Is there any way I can get Incisive to be more verbose in reporting the error and point me to the root cause of the problem in my testbench code?
  • StephenH
    StephenH over 7 years ago
    Unfortunately this is as much information as you can get for that exact error (I feel your pain, I've hit it a few times myself). The problem is caused by a multi-language TLM extension that is in the Incisive bundled version of UVM.
    Look in your code for any place where an unpacked struct is used with any kind of TLM port. If you know the code it shouldn't be too hard to find.
    You might also try adding +define+ML_UVM_DISABLE to your compilation command; this turns off the multi-language TLM extensions in UVM.
    If that doesn't help, try to find the offending struct and replace it with (or wrap it with) a class.
  • Ian88
    Ian88 over 7 years ago in reply to StephenH
    Ok, I found it and changed to a packed struct which fixed the problem. Thanks for your help.
