  2. Functional Verification
  3. How to read label inside a particular instance and check...
  • Subscribers 66
  • Views 14934
How to read label inside a particular instance and check its connectivity with the label of another instance
Garima M
Garima M over 7 years ago
I have multiple instance in top cell
Each instance has some labels inside it.
How I can get the instance name and read the labels inside it, and check to which label(of another instance) it is connected.
  • StephenH
    StephenH over 7 years ago
    I don't understand the question. Can you explain what you mean by a "label"? Even better, can you provide a small code example, so that you can refer to named items in the code instead of abstract words that might be misinterpreted?
  • Garima M
    Garima M over 7 years ago in reply to StephenH
    Hi Stephen,
    Thanks for quick response, I do not have any code as of now
    Say, there are 2 instances with their terminals connected together using metal routing. There are labels(placed using dbCreateLabel() command in metal layer. Eg: "G" on GATE terminal)  over the terminals.
    I want to read labels over those two connected terminals with their instance names & dump into a file.
    Eg:   I1(Instance)  "G"(Label)  connected to I2(Instance) "D"(Label)
    I am new to assura, so I am looking for a code to implement above logic using assura. Please help with the same.
  • StephenH
    StephenH over 7 years ago in reply to Garima M
    Ah! Now I understand why you were using this terminology! :) The forum you're posting in is aimed at front-end RTL verification users. You might get a more helpful response to your question if you ask in the CUSTOM IC forum: https://community.cadence.com/cadence_technology_forums/f/48.
    When you post there, do try to be as specific as possible so that you get a quick answer.
  • Garima M
    Thanks for the information Stephen.
