  2. Functional Verification
  3. DRM job removed. Job 2751721[3] removed by DRM. DRM Job...
  • Subscribers 66
  • Views 1068
DRM job removed. Job 2751721[3] removed by DRM. DRM Job status: TERMINATED Debug aids: Job output:
Rolly
Rolly over 3 years ago
Hi
Recently while I'm trying to fire regression for the collection of code coverage but I'm seeing some error saying DRM job removed only for two testcases (on running a standalone test with failing seed i could not see any failures, errors in simulation)so on checking log file i could see errors related to access issue from Backdoor, so I fixed the issue giving -access +rwc. Now after giving the access, increasing count number to the testcases and changing the queue to unlimit, i'm seeing the same following error.
DRM job removed.
Debug aids:
