  2. Functional Verification
  3. PSL endpoints and ended()
  • Replies 12
  • Subscribers 66
  • Views 22920
archive over 20 years ago
I need to write a property that states if conditon A occurs then SeqA or SeqB must have occured.
The PSL built-in ended() is not supported in IFV 5.7-s5.  So, I can't do either of these:
always {A} |-> {ended(SeqA) | ended(SeqB)}
never (A & ~(ended(SeqA) | ended(SeqB))
Also, I get this error when calling SeqA and SeqB endpoints.
endpoint SeqA ...
endpoint SeqB ...
always {A} |-> {SeqA | SeqB}
"Endpoints and sequences are illegal as verilog operands."
Does anyone have another idea how this can be done?
Ross
Originally posted in cdnusers.org by weberrm
    I am using it inside a vunit.
    I also check the cds_assertions stubs-file in the cadence installation directory (where functions as prev, next,.. are defined). ended() is not defined in there.
    Stijn
    Originally posted in cdnusers.org by stijn
    I just received confirmation that this is not supported in VHDL, see also the KPNS in the 5.82 release:
    http://sourcelink.cadence.com/docs/files/Release_Info/Docs/abvKPNS/abvKPNS5.82/abvKPNS.html#1011834
    I recommend that you contact your support person and have him file a PCR or log a service request through sourcelink.
    Nevertheless, the endpoint syntax still works, even in VHDL.
    Joerg.
    Originally posted in cdnusers.org by jmueller
