  2. Functional Verification
  3. C++ Object life cycle through SV DPI
  • Replies 11
  • Subscribers 66
  • Views 23566
archive over 19 years ago
Hi all,
I have a C++ Object life cycle through SV DPI problem.
For example, I have a C++ reference model class named ALU.  Only one public function revealed to client (e.g. ALU::ALU_EXEC) and was encapsulated in DPI(ALU_EXEC_DPI) . And there are two types of ALU commands was entered to ALU::ALU_EXEC. One is setup ALU parameters (i.e. setup the ALU class private member) , the other is calculating the result.
The question is when I leave DPI, the ALU object is eliminated and all the setup parameter is cleared, right? So can I keep a C++ Object even after I leave DPI (i.e. is the C++ Object life cycle only as long as DPI call life cycle).
My friend suggest me to return all the ALU parameter out to SV and re-enter these parameters to ALU through ALU_EXEC_DPI when I call the ALU reference model. But it may break the model encapsulation :(
May be my question is not very clear and any suggestions are welcome!
Davy
Originally posted in cdnusers.org by davyzhu
    Hi Vivek,
    After discussion and reading LRM, I have tried svPutUserData() and svGetUserData() to to store and load object in C layer. It works well for me. And thank you for your suggestions :-)
    Best regards,
    Davy
