  2. Functional Verification
  3. Error related to OVM
  • Subscribers 65
  • Views 14188
archive over 17 years ago
Hello friends,
                     I am trying to do my UVC environment up, but i am facing 2 errors which will be pasted below.
typedef class *_MASTER_trans;
ncvlog: *E,TYDMSC (./INCA_libs/irun.lnx86.06.20.nc/svpplib/specials/tlm_if_base_*_MASTER_trans_*_MASTER_trans.svi): The class specified in the typedef was never declared.
typedef class *_SLAVE_trans;
ncvlog: *E,TYDMSC (./INCA_libs/irun.lnx86.06.20.nc/svpplib/specials/tlm_if_base_*_SLAVE_trans_*_SLAVE_trans.svi): The class specified in the typedef was never declared.
        module worklib.*_tb_top:sv
                errors: 2, warnings: 0
irun: *E,VLGERR: An error occurred during parsing.  Review the log file for errors with the code *E and fix those identified problems to proceed.  Exiting with code (status 1).
-Raghavendra
Originally posted in cdnusers.org by raghavendrap
    Not quite sure why this is occurring. I will need to see more of your code to diagnose this any further. Can you please post the code around the typedef, the MASTER_trans class definition, and the class definition that uses the MASTER_trans.
    Tim
    Originally posted in cdnusers.org by tpylant
    Also, class name probably folllow the same guidelines as all other Verilog naming guidelines where names must begin with a alpha character or underscore.
    Tim
