  2. Functional Verification
  3. running 2 cross dependancy tests:
  • Replies 7
  • Subscribers 65
  • Views 15535
archive over 17 years ago
hello, i'd like to make an inout file interface between 2 dut's that feeding each other with data (to imitate the operation of socket). therefore, each dut test process reads data from one file and writes data to another, whereas the other dut, does the same only with opposite files. my question is whether specman can deal reading and writing to/from the same file on the same time without causing deadlock. should i use some sort of mutex to avoid the situation when one dut test process open a file for reading, but there's nothing to read, while the other process cannot write data to this file since it's already opened for reading by another process. perhaps you have a better solution without using files ? thanks, Zohar
Originally posted in cdnusers.org by zcabeli11
    Hi Zohar,
    Can you give a few more details about what you need to achieve?
    - What is the physical interface (e.g. data-bus/Ethernet/USB etc.) between these two DUTs?
    - What type of data is exchanged on this interface (e.g. data read/write transactions or data-packets)?
    - How is your simulation set up? Are the DUT models in HDL or SystemC or e? What is the implementation of the "dut test process" for each DUT? An HDL or SystemC process? A TCM in e?
    Dean
    Originally posted in cdnusers.org by ddmello
    A: my file interface is simulating data-bus
    A: data RW transtactions (bus length is 40bits, and i split it to 4 data lines length 10 bits each)
    A: i'm working on specman (e) environment, and that's the impementation of each dut test process.
    i'd like to denote that both dut test processes are running seperately on the same time (not necessarily on the same machine) and the file is the only connection between them. i'm wondering if there's a better solution than my current usage of files.
    i hope i manage to clarify things ...
    thanks for the help !!!
    Zohar
    Unfortunately I cannot share the code but we did something like what you need using Unix sockets.  See the following paper:
    http://www.dvclub.org/images/Presentations/Arthur_Q207.pdf
    This page: http://www.sutherland-hdl.com/pli_book_examples.html
    has a link to "David Robert's Socket Example" which is a good starting point.
    Enjoy,
    /Ed
    Originally posted in cdnusers.org by earthur
    Hello again,
    thank you very much for posting this valuable link. it's pretty relevant to me and i'm currently trying to use it in my objective.
    however, this code is simulating socket between a verilog application and C program, and i need socket between both verilog programs.
    furthermore, i'd prefer that my socket will run under specman environment since i right now i'm running my socket from 2 different speman tests, each one is responsible for another DUT in IO operations with the other DUT, and generating other requested data. this socket impemented in C code ( and i'm not sure if it's possible to combine it with specman) and i need to run it someway in the background, and make it transparent to the running DUT's, so there won't be any synchronization problems...
    if you know to integrate this C code with my current available test, i'd be happy to know How.
    thanks again,
    Zohar
    Zohar,
    See Chapter 17 of the Specman Usage manual "Co-Verification Link" and see the examples in $SPECMAN_HOME/examples/cvl.
    This might be just what you're looking for.
    /Ed
    i've been looking at Chepter 17, but unfortunately it doesn't contain any information about how to make Co-verification between 2 duts that are both written in verilog, and running with different specman processes. the question is whether i can use the Co-verification specman interface on both sides (and not specman / C as it shown in the manual) ?
    thanks,
    I'd take the Specman example $SPECMAN_HOME/examples/cvl/verilog|qvh/xor and try running it.
    Then I'd modify it and replace xor_driver.c with a Specman version and see if that works....Shouldn't
    take more than half an afternoon.
    /Ed
