  2. Functional Verification
  3. order of execution:
  • Subscribers 65
  • Views 13632
order of execution:
archive over 17 years ago
i've got a specman test and some extension which i wanna wrap my test with. so i can trivially add import line for the test in the beginning of the extension file. but what if i want that the extension code will compiled before the tets, without imporing the extension from the test. can i just import the test at the end of the extension code ? thanks,
Originally posted in cdnusers.org by zcabeli11
    You can create a top file that takes care of importing all e files in the right order. But, keep in mind that it is impossible to extend a struct before it's initial definition. You might need to "rephrase" some of the definitions :-)
    Yaron
    Originally posted in cdnusers.org by thinkverification
