  2. Functional Verification
  3. OS Signal 11 (segmentation violation)
  • Subscribers 65
  • Views 13997
archive over 17 years ago
I would like to call a function in systemc from specman. I wrote the type convertor, defined method port, connect it to the function in systemc block. Compilation, elaboration are all done.
When I call the function through method port, I got the fatal error,
Can anyone please tell me what could be the reason/reasons to cause this error? Thanks
Originally posted in cdnusers.org by twk1156
    This is usually a problem with some pointer in C, either you're accessing a null pointer or some other mistake.
    Have you tried a very simple SystemC function called from Specman, just to test your linking?
    Try just a dumb "hello world" first...
    Originally posted in cdnusers.org by stephenh
