  2. Hardware/Software Co-Development, Verification…
  3. SystemC Adder
  • Subscribers 49
  • Views 14616
SystemC Adder
Saggiatorius
Saggiatorius over 18 years ago
 Hi, I need to model a simple auxiliary processing unit in SystemC using the Simple Bus architecture. The processing unit I have to implement shall take a pair of numbers as input, sent by address AD and AD+1 (AD is the unit's addressing space). After having received the second operand, the unit runs the sum and then makes available the result at the location AD+3.
I have no idea mainly on the addressing issued. Can you help me?
 Here you may find the interfaces of the simple bus:
- master side: svn.greensocs.com/.../simple_bus_blocking_if.h
- slave side: svn.greensocs.com/.../simple_bus_slave_if.h
