  2. Hardware/Software Co-Development, Verification…
  3. About Allegro aware of setting
  • Subscribers 49
  • Views 14948
Raam
Raam over 17 years ago
i want to save my colour settings and when colour setting changed, then i want to change back for my colour setting, is there any option? please give me the hints to do.........
  • oldmouldy
    oldmouldy over 17 years ago
    You would probably get a faster answer in the PCB Design forum. You would need to be running Allegro tools versions 16.01, or 16.2, then you can export and import colour parameters which will affect which colour is assigned to which object. In 16.0 you can only save the colour pallette rather than the colour assignments. If you are needing to save specific views, use View>Color View Save, these views will then appear in the Visibility drop-down.
