  2. Hardware/Software Co-Development, Verification…
  3. About the object value of system verilog in ncsim
  • Subscribers 49
  • Views 15865
Rex Chen
Rex Chen over 17 years ago
I have a system verilog program as follows:
program p;
   class Foo1;
     int limit;
     function new(int i);
       this.limit = i;
     endfunction
     task print(int limit);
          $display("Limit %0d",limit);
     endtask
   endclass
   class Foo2;
     int limit, array[];
     Foo1 f1;
       f1 = new(i);
       this.limit = i;
     endfunction
       for (int i=0;i<limit;i++)
            $display("%m: array[%0d]=%0d : %0d",i,array[i],limit);
       f1.print(limit);
     endtask
   endclass
   int limit = 2;
   initial begin
     Foo1 bar1;
     Foo2 bar;
     bar = new(5);
     bar1 = new(6);
     #5;
     bar.array = new[limit];
     bar.print(limit);
     bar.print(1);
     bar.print(2);
     bar1.print(3);
     bar1.print(4);
     end
endprogram
When I use "ncsim -tcl" to debug, I found that I can't get the object value. For example,
./class_in_class.sv:31      bar = new(5);
ncsim>  run -step
./class_in_class.sv:32      bar1 = new(6);
ncsim> value bar
ncsim: *E,PNOOBJ: Path element could not be found: bar.
ncsim>
I have no idea why the value of object can't be dumped. Should I specify the full scope name of "bar"?
I have tried "p.bar" but it doesn't work. Please someone tell me if it is a limitation or what should I type to get the object value. Thanks a lot! My ncsim version is 08.10-s008.
Best regards
rex
  • Rex Chen
    I found that I can get the object address with correct scope:
    Current scope is (p)
    Highest level modules:
    p
    ncsim> value p.unmblk1.bar
    @1_1
    ncsim>
    However, is there any way to get the value of object "bar"?
    Thanks a lot!
