  2. Hardware/Software Co-Development, Verification…
  3. cannot run simvision
  • Subscribers 49
  • Views 16060
bdatta
bdatta over 17 years ago
 I have verilo-XL simulator from the IUS5.8 release and Allegro from the SPB16.01 release.  I can run Allegro but when I try to run verilog-XL it fails when it tries to start simvision and gives the following strange error message:
Cadence/tools/verilog/tools/bin/64bit/simvision: line 62 Cadence/tools/verilog/tools/bin/64bit/simvision.exe: cannot execute binary file
Cadence/tools/verilog/tools/bin/64bit/simvision: line 62 Cadence/tools/verilog/tools/bin/64bit/simvision.exe: success
simvision proccess terminated before connection could be established
Allegro is installed in 'Cadence' directory and the IUS5.8(verilog-XL) is installed in the Cadence/tools/verilog directory
  • Mickey
    Mickey over 17 years ago
     Hi bdatta,
    I suspect that the issue is related to attempting to use verilog-XL with the 64bit version of simvision.  As and FYI there is no 64bit version of verilog-XL.
     Look into your PATH env variable and make sure that you have <IUS_install>/tools/bin prior to <IUS_install>/tools/bin/64bit.
    Best regards,
    Mickey
