  2. Hardware/Software Co-Development, Verification…
  3. Problem with XFRM_LINEAR Subcircuit
  • Subscribers 49
  • Views 17171
G Balaji
G Balaji over 17 years ago
I created a subcircuit using XFRM_LINEAR (subcircuit within subcircuit) and passed a parameter to this using SUBPARAM. But when I generate the netlist, It doesn't included the parameter on PARAM list and generated the following netlist.
This is resolved when I use 2 inductors with K instead of XFRM_Linear.
 Why?
.subckt X_TXl 1 2 3 4
K_TXl         L1_TXl L2_TXl 0.998
L1_TXl         1 2 {L1_X}
L2_TXl         3 4 250u
.ends X_TXl
  • oldmouldy
    oldmouldy over 17 years ago
    Hard to tell exactly what you did, or didn't, do from the supplied information, but the PARAM statement is missing to pass the parameter into the sub-circuit. Your model should look "something like":
    +PARAM: L1_X=10u
    L1_TXl         1 2 {L1_X}
    L2_TXl         3 4 250u
    .ends X_TXl
    This would have 10u as the default value. Using the Model Editor to create a Capture part would then have "L1_X" as an editable property on the graphical part for use in a schematic. See this PSPice User Guide on Setup parameter passing to a subcircuit using Subparam.
  • G Balaji
     To explain clearly what I did, please find attached snap shot of two models, where model – 1 uses two inductors and K. whereas in model – 2 XFRM_Linear is used instead.
    Given below are the netlists generated by model-1 and model-2 respectively and these netlists are created using “Create Netlist” command in capture project manager.
    Model - 1
    * source LIBRARY_TR
    .SUBCKT TR P1 P2 S1 S2 PARAMS: LVAL=10U
    C_C1         P1 N2433146  1n  TC=0,0
    L_L1_40         S1 S2  {Lval}
    Kn_K2         L_L1_40 L_L2_40     0.998
    L_L2_40         N2433146 P2  250u
    .ENDS
    Model – 2
    * source LIBRARY_XTR
    .SUBCKT XTR P1 P2 S1 S2 PARAMS: LVAL=10U
    X_TX1    N00597 P2 S1 S2 XTR_TX1
    C_C1         N00597 P1  10u  TC=0,0
    .ENDS
    .subckt XTR_TX1 1 2 3 4
    K_TX1         L1_TX1 L2_TX1 1
    L1_TX1         1 2 {LVal}
    L2_TX1         3 4 10uH
    .ends XTR_TX1
    Absolutely Model-1 doesn’t have any problem. But, in Model-2, as you said, It suppose to include +PARAM: L1_X=10u in XTR_TX1 subcircuit and when X_TX1 is called the value LVAL need to passed to this subcircuit.
    I’m expecting this to happen automatically as I’m generating netlist from capture project manager.
  • oldmouldy
    You have a subcircuit "calling" a subcircuit, in this case use the "@" construct, rather than the "{}" construct. If you specify the L1 value as "@LVAL" rather than "{LVAL}", the SUBPARAM parameter will be correctly substituted in the "called" subcircuit. Strictly speaking, the "{}" construct specifies a Global parameter, from a PARAM part, rather than a sub-parameter, from a SUBPARAMS part, although the "{}" construct often works!
