  2. Hardware/Software Co-Development, Verification…
  3. Corner simulation Path error
  • Subscribers 48
  • Views 745
sohaibafridi
sohaibafridi over 14 years ago
I am facing a problem here with my corner simulations. The base path provided for the corner simulation process is "/usr/cadence/SGB25V/tech/spectre/" which is added according to the valid path of the directory on my server. I assign the variables as cornerMOS.scs (the file which contains the corner values) and then I assign the corners as 11 and 22 because the file contains numerical heading of each corner case. Any idea why does the following error come up?, I have not assigned 11 or 22 as a file but just corners.
 Beginning Corners runs (session spectre1) ...
Generating and running corners ...
*Error* The specified path is not a valid directory:  "/usr/cadence/SGB25V/tech/spectre/11"
*Error* The specified path is not a valid directory:  "/usr/cadence/SGB25V/tech/spectre/22"
Regards
