  2. Hardware/Software Co-Development, Verification…
  3. passing 2-dimension array in DPI-SC
  • Subscribers 50
  • Views 15828
ravi999
ravi999 over 14 years ago
Hi
I am able to pass one bit vector as an argument for DPI-SC.
test.v:
module test;
import "DPI-SC" function int c_func(input bit [7:0] data);
bit [7:0] data;
int j;
initial begin
 data=8'h1;
 j=c_func(data);
end
endmodule
code.cpp
#include <iostream>
using namespace std;
#define NCSC_INCLUDE_TASK_CALLS
#include "systemc.h"
#include "svdpi.h"
int c_func(svBitVecVal h) {
 cout<<h;
 return 0;
NCSC_REGISTER_DPI(c_func)
Above code is working.
But I am unable to pass 2-dimension array as an arguement.
Is there any way to pass 2-D bit array as an argumenet for DPI-SC?
  • vjain419
    vjain419 over 14 years ago
     may be you will get some help from this example
     program main;
               import "DPI-C" function void get_nums(output logic [15:0] nums[10]);
               logic [15:0] nums[10];
               initial begin
                   get_nums(nums);
                   foreach (nums[i]) $display(i,nums[i]);
               end
          endprogram
    #include "svdpi.h"
          void fib(svLogicVecVal nums[10]) {
              int i;
              for (i=0; i<10; i++) {
                  nums[i] = i ;
    Vinay
