  2. Hardware/Software Co-Development, Verification…
  3. Plotting
  • Subscribers 49
  • Views 14998
Plotting
hannover
hannover over 14 years ago
 I simlated my circuit with dc-analyse.
The plotting of voltage or current of one of transistor is over this dc-analye as it is expected.
But how cant I plot this voltage or current over a certain voltage or current of the circuit?
I use ocean script to extract data and save it in txt file for my desired plotting.
But is it possible to give cammands in "Analog Design Enviroment/outputs/setting outputs/expression" for desired plotting?
 I will be thankful for any recommendation.
Best regards,
Sara
  • hannover
     I tried to find the solution:
    1. opening the calculator
    2. making an expression
    3. chosing x-axis
    4. opening the Axis/Editor
    5. chosing the made expression in section of "Plot vs."
    Best regards
    Sara
