  2. Hardware/Software Co-Development, Verification…
  3. IRUN and PlusArgs
  • Subscribers 49
  • Views 18358
IRUN and PlusArgs
jlang
jlang over 14 years ago
I am having issues trying to pass a $plus$args using IRUN.  Anyone have any clues?  Can we NOT use the +plusarg on irun command line?
irun command line:
**   irun -file simopts/rtl_opts.def -file chipfiles/chip_rtl.h -file chipfiles/chip_tb.h -top test -input scripts/core_test.rtl.0.tcl  +mytest
Code snippet to check for +mytest
// Code snippet to check for +mytest
 if ($test$plusargs(“mytest”)) begin
    $display("FOUND MYTEST");
end
// Here is what I see on the failed attempt to run simulation, which appears during elaboration step.
         Top level design units:
                test
if ($test$plusargs(âmytestâ)) begin
ncelab: *E,CUVHNF (./tbsource/tb_test_apcm_demo.sv,39|30): Hierarchical name component lookup failed at 'mytest'.
irun: *E,ELBERR: Error during elaboration (status 1), exiting.
  • Xinwei
    Xinwei over 13 years ago
     when you run it , pass it to irun like  irun -ncsimargs "+mytest"
