  2. Hardware/Software Co-Development, Verification…
  3. About UVM ML
  • Subscribers 50
  • Views 15529
About UVM ML
anubhaw2004
anubhaw2004 over 14 years ago
 Hi ,
 I am trying to use the UVM ML. But i am getting the problem. I am using the following comment to Mapping transction type from "e" to "sv".
  "irun -mltypemap_input <input-file> "
So please help me how i will pass the input file to this command. Lets take the example my "e" file is xyz.e.
  • erezs
    erezs over 14 years ago
    The mltypemap utlity comes with elaborate documentation the should give you all the information you'll need to get started. Using the cdnshelp utility, please look for Universal Verification Methodology->UVM Multi-Language Reference->6. mltypemap utllity.
    Basically, you give irun all the input files you need for compilation as usual, and provide a TCL command file containing instructions specific to mltypemap on how to map the needed types. For example. assume you have an e file foo.e that contains struct 'my_pkg::bar' that you want to map to SV.  Your TCL file can look like:
      // TCL file for mapping e type to SV
      maptypes -from_type e:my_pkg::bar -base_name base -to_lang sv
    And the irun command:
      irun foo.e -nosncomp -mltypemap_input do_map.tcl
    Please lt me know if you require additional information.
