  2. Hardware/Software Co-Development, Verification…
  3. Font size of C-to-Silicon GUI
  • Subscribers 50
  • Views 16063
GiuseppeDG
GiuseppeDG over 13 years ago
Hi!
I am running C-to-Silicon on CentOS 6.3.
Currently the fonts of menu bars are too small for being easy to read. Is there a way for increasing the fonts size?
On Google I found some configuration files, e.g, .cdsenv, but I ignore if they apply to any Cadence tool.
 ui textFont string "-*-courier-medium-r-*-*-12-*"
Can you help me?
Thank you
  • Mark Warren
    Mark Warren over 13 years ago
    Hi  Giuseppe,
    You can change the font sizes in CtoS via the main menu  FIle->Preferences
    Then select Commnad Output,   and select a larger text zoom number.
    Note that the text sizes in most other windows is controlled by the zoom box at the top of the CtoS GUI window.
    hope this helps.
    -mark
  • GiuseppeDG
    Now I have similar problem with cdnshelp. I was able to fix the SimVision fonts size. In that case the solution is different from CtoS
    http://www.cadence.com/Community/blogs/sd/archive/2012/08/17/simvision-fonts-for-ubuntu.aspx
    Now the Cadence Help interface remain. Do you know how to fix it?
     Thanks.
