  2. Hardware/Software Co-Development, Verification…
  3. How to plot current versus voltage curve in waveform graph...
  • Subscribers 49
  • Views 19015
How to plot current versus voltage curve in waveform graph XL with cadence 6.1.4
MathieuM
MathieuM over 12 years ago
Hello !
I need to plot a current versus voltage curve (with Waveform Graph XL version Thu Dec 2 23:00:39) after running a transient simulation with cadence version IC6.1.4.500.10
I don't find the way to replace time axis with a voltage axis (or anything) ? Is there a solution to solve this problem ?
Thank you very much
MathieuM
  • abhierao
    abhierao over 12 years ago
    You can replace the x axis to any parameter by going to PLOT>AXIS SETTINGS>AXIS VARIABLE then selecting your desired node for the x axis. As you need voltage vs current waveform i prefer you to use a dc sweep analyses with current sweeping through some values on X-axis & voltage on the Y-axis.
